I have a '99 Kenmore side-by-side that has been acting up. It was confusing at first because it did get cold, just not all the way, and would have warming cycles. Other times it would work fine, and with nothing in it and us playing with the controls, would merrily run the fresh food side down to 36. If I turn it off for a while, it starts up fine. But after a while, the compressor's not running and it needed to be turned off for a while.
Thanks to info here an elsewhere, I went through the check list. The (manual) defrost timer is working properly. The coils weren't bad but got seriously cleaned with a coil brush and a few bursts from the air compressor :rolleyes:. I then moved on to the compressor, checked it and it appeared to check out (2.8 ohms, 3.7 ohms, 6.5 ohms, nothing grounded) and the one thing I couldn't check was the solid state relay, so I ordered one of those.
Sadly, replacing the relay was not the ticket. So scratching my head I rechecked the compressor, which was hot but read as before, and I even pulled the starter cap and found it was well within tolerance. Messed with it some more, cooled it down with a damp cloth (unplugged!), and realized it was on a try-to-start 5 sec, do-nothing 60 second cycle, (which is why it got hot.)
In the process, I realized that I couldn't hear the evaporator fan, though I had heard it previously. So I pulled the back panel, and sure enough, the evaporator fan was sitting there doing nothing. And (like a PC fan) once I gave it a kick, it spun right up. Dying fan, erratic. I checked it out and was surprised to see there was a -lot- of play at the fan end axle, like 1/4" or such. Is that right?
So now the question I'm hoping you'll weigh in on - can the evaporator fan (or lack thereof) be the cause of the compressor overheating? Or is it more likely to be the compressor bearings going? And is the end of the fan shaft supposed to have that much play?!
After all the work I did on the second pass, I turned it on and realized I could do a sort of evap fan 'test'. I set the dials to max cold to keep the fan running, and buttoned it up. It's been running for an hour straight now, which seems to suggest the compressor is functional. On the other hand, the compressor hasn't had to restart either yet, and bad bearings in motion tend to stay in motion. But in many 'failed evaporator fan' pictures the evap coils are frozen into a solid block, which meant the compressor continued to function well after airflow was basically gone.
So getting mixed signals on this one and don't want to sink the money into a new evaporator fan if the unit is fundamentally walking dead. Any guidance you could provide would be much appreciated.
