Having trouble with temperture. The oven doesn't heat up right. the heat elements don't have burn marks,but will not glow when you start the oven. The temperture dial doesn't glow when raising temp. can i have a problem with the temp dial or can it be both things.
thank you
Richard Hess
THIS FORUM IS DEAD!!!!!!! |
