chilldad
#1 Posted : Tuesday, November 6, 2007 12:57:03 PM(UTC)
chilldad
The refrig and freezer sides stopped cooling. The evaporator fan motor needed replacing and I did that. Now, the freezer side is cooling down to 0 degrees but the refrig side is not cooling and stays around 60 degrees. The air duct at the top to the right of the fan is clear and open. What do I need to do to get the refrig side to cool?
kooler
#2 Posted : Wednesday, November 21, 2007 1:53:37 PM(UTC)
kooler
Not to sound silly but are you sure you installed the fan blade correctly when you replaced the evaporator motor?... If it's flipped the wrong way it won't move enough air to blow into the fridge...
GE Profile side by side refrig not cooling (Refrigerator & Freezer Repair)
by j4son 9/22/2011 10:53:34 AM(UTC)
