I would like to know how to replace the coupling between the motor and gearbox.. The one on the machine is part plastic or nylon and is cracked. Machine therefore has no drive. Any help would be appreciated. Thanks James
Remove the cabinet, Remove the Pump, Remove the Motor, Replace the coupler, Reverse the above. Should take you about 20-30 min.
