leglesscrow
#1 Posted : Tuesday, January 6, 2009 12:01:58 PM(UTC)
leglesscrow
A friend of mine recently bought a new dryer and i took the old one apart and took the motor out (part # 3395654). I want to wire it up to run and use it like a small fan and possibly a small heater in my shop but i cant find a wiring diagram to figure out how to straight wire it so i can put a switch on and plug it straight in. Basically what i need to know is: There is a Blue wire, a purple wire, and a white/orange wire on the motor. There is a Black wire, Green wire, and a White wire on the power cord i'm connecting. Which wire should connect to where and which line should i put my switch in?
#2 Posted : Wednesday, January 7, 2009 3:04:04 PM(UTC)
I hope the wiring diagram for a dryer with a such motor will help you.
Guest
#3 Posted : Monday, May 15, 2023 2:52:37 PM(UTC)
Guest
Rank: Guest
United States
Let’s see
