Pegleg37
#1 Posted : Tuesday, October 4, 2011 10:16:55 AM(UTC)
Pegleg37
I found a small water puddle in front of the washer and I didn't know where it came from at first and then I noticed that at the certain time during the washing cycle, water comes out from the bottom if the front door....(not all the time during washing) Is it because the Front Bellow Tub Seal is wearing out and needs to be replaced? I was going to buy that part but hoping to make sure that will fix the leaking issue. Is this problem common?
dnlow
#2 Posted : Tuesday, October 4, 2011 8:30:48 PM(UTC)
dnlow
Have you looked underneath to see where the water is coming from. It could be one of several possibilities. If you could bypass door switch and remove outer cover you could watch it operate and see where the water is coming from. I am not a master tech like others here but I see five leaky water pumps to every one leaky tub.
Pegleg37
#3 Posted : Wednesday, October 5, 2011 9:27:11 AM(UTC)
Pegleg37
I see small stream of water comes out from the door seam(bottom part of the door of course) It doesn't start coming out at first, only at certain times of whole cycle fo washing... strange....
dnlow
#4 Posted : Thursday, October 6, 2011 5:37:49 AM(UTC)
dnlow
I am sorry I miss read the paragraph, did not notice it was front load washer. I do not have experience with these type of washers. The simplest thing would be to check the door seal and see if it is damaged in any way and make sure the whole area is clean so a good seal can be made, changing the front bellows may be the solution. I would think paying someone to look at it may be worth while. They could diagnose the problem for you and it could be something you could fix yourself. That way you are not changing parts here and there until you remedy the situation. Other than that I can be of not much help. Sorry about that.
Pegleg37
#5 Posted : Thursday, October 6, 2011 7:50:32 AM(UTC)
Pegleg37
Thank you for replying. Well, we cleaned around the seal and still leaks, so I think we will replace the rubber seal and see what happens. Thanks anyway.
