alshadow
#1 Posted : Monday, October 3, 2011 6:34:56 PM(UTC)
alshadow
Please assist how to find the defrost timer of my Admiral ASD2120DRW model. Thanks!
#2 Posted : Tuesday, October 4, 2011 5:59:02 AM(UTC)
Replacement parts for ADMIRAL ASD2120DRW REF - SXS/I&W | AppliancePartsPros.com
Defrost timer is Item 13 in Section 2.
There is often a hole in the cover/mount to let you rotate the timer cam without disassembling everything.
alshadow
#3 Posted : Tuesday, October 4, 2011 6:32:34 PM(UTC)
alshadow
Thank you Denman. Not really sure if the defrost timer is the issue or the heater itself but I think is either one 'coz the coils have ice buildup on them. After I had the freezer defrosted for few hours and turn the refrigerator back on, my refrigerator started cooling as normal.
#4 Posted : Wednesday, October 5, 2011 2:16:40 AM(UTC)
OK, let it run for a while so there is frost on the coils again.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 13 in Section 2) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit. Unplug the heater/defrost thermostat combo (Item 12 in Section 4) from the wiring and measure it for continuity, usually around 20 ohms or so.
Note that the defrost thermostat opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast or the timer motor is not advancing it into defrost..
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
For the timer motor you can mark the timer cam and a lined up mark on the cover. Let it run for a couple hours if the marks still line up the timer is not advancing.
alshadow
#5 Posted : Friday, October 7, 2011 4:48:15 PM(UTC)
alshadow
Thanks for the info, Denman. I will try to do as you instructed. I am a novice to this kind of stuff, so hopefully that I do not screw up. :)
alshadow
#6 Posted : Saturday, October 8, 2011 6:54:03 PM(UTC)
alshadow
Here is my update, Denman. The coils are heavily iced/frosted again. I did manually force a defrost cycle by turning the defrost timer cam 'till the fans and compressor turns off and waited about 15 minutes but the defrost heater did not come on. I unplugged the unit and unplugged the heater/defrost thermostat combo from the wiring and measure it for continuity, but I did not get any resistances on my multi meter. So, I would assume that the defrost heater is not functioning. Kindly suggest.
#7 Posted : Tuesday, October 11, 2011 10:44:41 AM(UTC)
Yes I would replace the heater/defrost thermostat assembly.
Part number: AP4072797
alshadow
#8 Posted : Tuesday, October 11, 2011 5:06:19 PM(UTC)
alshadow
Thank you. I will order the mentioned part and update you once I have it installed. I found this forum very expedient.
alshadow
#9 Posted : Saturday, October 22, 2011 5:52:57 PM(UTC)
alshadow
Hey Denman, I have installed the new heater/defrost thermostat assembly last week (wow, the shipping was fast!) and my refrigerator is now cooling as normal. The coils are not getting heavily frosted anymore. Thanks for all your help! :)
#10 Posted : Sunday, October 23, 2011 3:55:24 AM(UTC)
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
