martybp
#1 Posted : Monday, October 3, 2011 7:30:23 AM(UTC)
martybp
The inner glass requires replacement on the oven door. I purchased a new glass but am having a problem removing the oven door. I followed your instructions to open the door to the first stop and lift but the door does not lift. On each side of the hinge attached to the oven are plates with a philips head screw into which the door hinge slides. Is it necessary to remove these to remove the oven door? Thank you Marty
#2 Posted : Monday, October 3, 2011 11:12:18 AM(UTC)
Hi Marty,
The instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KGRT607HBL9 GAS RANGE | AppliancePartsPros.com
File Attachment(s):
oven door removal and replacement (Oven Repair (including Ranges and Cooktops))
by gmzal 7/8/2014 3:47:40 PM(UTC)
Oven Door Removal (Oven Repair (including Ranges and Cooktops))
by Rayles 5/28/2014 2:06:30 PM(UTC)
Oven Door Removal/Hinge Repair (Oven Repair (including Ranges and Cooktops))
by Ken1000 5/23/2013 8:59:58 AM(UTC)
Oven door removal (Oven Repair (including Ranges and Cooktops))
by jyork1961 3/5/2013 10:57:27 AM(UTC)
by DRMay 1/4/2013 10:00:09 AM(UTC)
Maytag mgr5775qdq oven door removal (Oven Repair (including Ranges and Cooktops))
by ocirus73 11/30/2012 7:45:36 AM(UTC)
Whirlpool oven door removal (Oven Repair (including Ranges and Cooktops))
by ts756 8/17/2012 12:55:14 PM(UTC)
by mohinder 2/23/2012 12:45:55 PM(UTC)
by stevesr49 2/15/2012 7:59:04 AM(UTC)
Kitchen Aid oven door removal - going crazy (Oven Repair (including Ranges and Cooktops))
by sun4jessi 10/19/2011 3:08:54 PM(UTC)
Kitchen Aid oven door removal (Oven Repair (including Ranges and Cooktops))
by Grandmm 1/16/2011 11:55:55 AM(UTC)
by Dannyl 11/21/2010 7:22:41 AM(UTC)
Jenn Aire Oven Door Removal (Oven Repair (including Ranges and Cooktops))
by JimmyW 2/4/2010 11:12:39 AM(UTC)
Kitchenaid Oven Door Removal (Oven Repair (including Ranges and Cooktops))
by jrepac 8/3/2009 7:36:03 AM(UTC)
by beast 6/4/2009 11:21:16 AM(UTC)
