sjskee2
#1 Posted : Tuesday, January 6, 2009 3:35:42 PM(UTC)
sjskee2
Dishwasher Arm does not turn and dishwasher does not clean. Dishwasher still makes noise as if its working.
#2 Posted : Wednesday, January 7, 2009 6:16:57 AM(UTC)
Here is your parts breakdown
Model Search
Here is a link that may help
http://www.applianceaid.com/maytag-dish.html
The first couple things are
1. Check to make sure unit is getting water. Most units fill to just below the heating element.
2. Are the filter screens clean.
sjskee2
#3 Posted : Friday, January 9, 2009 9:06:31 AM(UTC)
sjskee2
The unit is getting water, but it does not drain when its off.(although I don't know if its supposed to). Also i cant figure out how to get to the filter screens or any of the pump and motor.
#4 Posted : Friday, January 9, 2009 3:40:43 PM(UTC)
The following should help I believe they use the same pump type
http://www.servicematters.com/m...ibrary/docs/16007823.pdf
Guest (4)
