I have A GE Profile frige (PFSS9PKYASS) with a Samsung ice maker (DA97-07365A). After replacing the water filter, the ice maker made very very large cubes and the pressure from the in-door water dispenser increased. Now the ice maker will not work (cycle) automatically. It will work only when I push the reset button. The maker will cycle, dropping the ice and then refill. when the maker refills a "ding-dong" tone sounds (error code?). Then, as stated above, the ice maker will not drop ice unless I push the reset button. I have removed the ice maker from the refrigerator for several hours (hoping to reset it) but upon reinstalling it, the same continues. I have very good water pressure, the temp in the ice compartment is always -2 or below and I replaced the original water filter with the same model. Will a new ice maker fix this issue or is there something else wrong? :(
Anyone have any idea? Anyone....? Is this thing on? Hello? :confused:
I have the same problem with the same model ice maker and brand name fridge! Does anyone know what's wrong or what to try?
I have been told to unplug the refrigerator for about 10 minutes and plug it back in. It didn't work, just the same as pushing the reset button. I have inquired with some repairmen who have mentioned maybe the circuit board needs to be replaced. :(
