russkmeredith
#1 Posted : Sunday, January 4, 2009 2:42:36 PM(UTC)
russkmeredith
I am having troubles with my oven lighting I have replaced the igniter twice and the spark board once. Sometimes it lites and sometimes it wont. Any suggestions
kayakcrzy
#2 Posted : Monday, January 5, 2009 3:29:57 AM(UTC)
kayakcrzy
It sounds like you need another ignitor. Check the wireing, from the gas valve to the ignitor, and make sure it is in good shape. Tom ApplianceEducator.com
russkmeredith
#3 Posted : Monday, January 5, 2009 6:50:08 AM(UTC)
russkmeredith
I have checked the wiring and it is fine. This thing is driving me nuts. I was cooking a Turkey breast yesterday and it should have only taken 1.5-2.0 hours and it took almost 4 hours to cook it . After I went and bought chicken for supper, the oven worked fine fired up every time. Figures huh
#4 Posted : Monday, January 5, 2009 6:53:40 PM(UTC)
Have you replaced the igniter only or you've replaced the burner too?
kayakcrzy
#5 Posted : Tuesday, January 6, 2009 4:28:29 AM(UTC)
kayakcrzy
Its those darn Gremlins again. Tom ApplianceEducator.com
russkmeredith
#6 Posted : Tuesday, January 6, 2009 6:51:22 AM(UTC)
russkmeredith
Yes you are right gremlins. I checked the burner and it is clean. I have checked about every thing I can think of I am going to clean the ignitor and try again.
#7 Posted : Tuesday, January 6, 2009 8:23:17 PM(UTC)
Have you replaced the burner together with the igniter?
kayakcrzy
#8 Posted : Thursday, January 8, 2009 4:20:52 AM(UTC)
kayakcrzy
Heck replace it all!!! LOL!!! Check all your connections down there at the gas valve assembly. Tom ApplianceEducator.com
whirlpool range GS395LEG (Oven Repair (including Ranges and Cooktops))
by Guest 3/18/2024 12:17:23 PM(UTC)
whirlpool range Model xfg374lvs (Oven Repair (including Ranges and Cooktops))
by Guest 1/21/2023 11:09:59 AM(UTC)
I have a whirlpool range Model #WFG505M0BS3 (Dishwasher Repair)
by Kbarbie 7/2/2022 10:13:00 AM(UTC)
Whirlpool range GR399LXGT2 (Oven Repair (including Ranges and Cooktops))
by Guest 1/29/2022 7:27:05 AM(UTC)
Hidden bake element whirlpool range (Oven Repair (including Ranges and Cooktops))
by Guest 8/12/2021 10:05:04 AM(UTC)
Whirlpool Range issue (Oven Repair (including Ranges and Cooktops))
by Guest 7/25/2021 9:31:56 AM(UTC)
Whirlpool range oven doesn't heat (Oven Repair (including Ranges and Cooktops))
by Guest 5/10/2021 12:58:16 PM(UTC)
Whirlpool range touchpad won't display (Oven Repair (including Ranges and Cooktops))
by kleindon 10/6/2017 7:15:22 PM(UTC)
No bake, no broil on Whirlpool range. Help! (Oven Repair (including Ranges and Cooktops))
by JamesTheScot 8/13/2015 8:31:22 PM(UTC)
Whirlpool range supply voltage problems (Oven Repair (including Ranges and Cooktops))
by TheSunny1 11/11/2014 5:56:36 PM(UTC)
Whirlpool range cooktop won't work code 79 (Oven Repair (including Ranges and Cooktops))
by jdgough624 11/9/2014 10:06:55 AM(UTC)
Whirlpool range no digital display or oven working (Oven Repair (including Ranges and Cooktops))
by bdbwtie 4/5/2014 6:57:10 AM(UTC)
Whirlpool range door won't open. (Oven Repair (including Ranges and Cooktops))
by Electechab 1/27/2014 11:07:17 AM(UTC)
whirlpool range top not working (Oven Repair (including Ranges and Cooktops))
by bck621 1/6/2014 7:54:41 AM(UTC)
Whirlpool range (Oven Repair (including Ranges and Cooktops))
by AlanO 10/2/2013 2:54:13 PM(UTC)
