When the spin stops there is a loud screech. What causes this?
:) My Maytag Mav6000aww Makes A Loud Screeching Sound When The Spin Cycle Ends. What Causes This?
:) MY MAYTAG WASHER MAV6000AWW MAKES A VERY LOUD SCREECHING NOISE WHEN THE SPIN CYCLE COMES TO AN ABRUPT STOP. wHAT COULD BE THE CAUSE OF THIS?
Probably a sticking brake inside the brake housing. Might be due to a tub seal leaking water on it and the brake bearing, it's a big job to fix properly.
