Dryer wont start. Put a load in, went to bed and the dryer was still running. Shut the dryer off. LAter that day the dryer would not start. I did replace the thermal fuse, but no luck???
Check the door switch assembly.
Nat
You might check the power to the dryer, and you also might have a broken dryer element if the dryer ran all night. Tom ApplianceEducator.com
