closs2sx
#1 Posted : Tuesday, January 6, 2009 5:32:12 AM(UTC)
closs2sx
the top element in my oven stays on unless I unplug the power to the range and when I plug it back in the top element in the oven comes back on the display is showing pf. what parts do I need to fix it or would it be better to buy a new oven?(more cost effective)
#2 Posted : Tuesday, January 6, 2009 7:53:21 PM(UTC)
Most likely the problem is a relay on the control board stuck closed. The control board has to be replaced.
- The part number for the control board is AP3174668
closs2sx
#3 Posted : Tuesday, January 6, 2009 8:04:42 PM(UTC)
closs2sx
thanks Gene
AugustM
#4 Posted : Saturday, December 20, 2014 10:46:04 AM(UTC)
AugustM
I have had the same thing happen about once a year for 4 or 5 years now. Someplace on the Net, that I cannot find again now, I came across a temporary fix that has worked for me.
Unplug the oven or turn off the circuit breaker and let it cool overnight.
When you plug it back in again, the broiler will turn on. That's the problem.
Turn on the CLEAN cycle and give it just a minute or two to warm up.
Then pull the plug or switch the circuit breaker.
Give it a little while to cool down again and then plug it back in.
At this point, with luck, you've gotten the relay to reset and the broiler won't come back on --- until the next time it overheats due to lots of broiling or baking.
At least, that's how it worked for me yesterday. Your mileage may vary. This is not a permanent fix and I'm not a pro.
