The dryer i got wants to get hot on top I,am not sure why it dose this i do not want something to burn out can someone tell me what is wrong?
Originally Posted by: Ned Gruver  The dryer i got wants to get hot on top I,am not sure why it dose this i do not want something to burn out can someone tell me what is wrong? I Just replaced the moter and the heating coil, do i have wiers turned around.
Here is the wiring diagram. http://manuals.frigidaire.com/p...ebster/134509400efsa.pdf[COLOR="DarkRed"]do i have wiers turned around.[/COLOR] I cannot say all you can do is use the wiring diagram to see if they are hooked up correctly. Unplug the unit and disconnect it from the vent system. Now try a run. If it now dries OK odds are the vent system needs checking/cleaning. Be sure to check that the louvers on the outside of the house open correctly. If you do not want any lint in the house. Take a pair of pantyhose. Put one leg into the other and then attach this to the dryer's vent. Leave enough room so the pantyhose can balloon out like a windsock. Both the above will let you check the temperature and the air flow. Check that the seals in the air flow path in the unit are OK. Check that the element is not grounded. Check it with a meter, should be around 10 to 12 ohms. Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it. |
THIS FORUM IS DEAD!!!!!!! |
