marksholander@hotmail.com
#1 Posted : Monday, January 5, 2009 4:41:46 PM(UTC)
my washer is 3 months out of warranty and will no longer spin dry!
libertyappl
#2 Posted : Monday, January 5, 2009 6:51:46 PM(UTC)
libertyappl
Remove the rear panel and inspect the belt.
Nat
#3 Posted : Tuesday, January 6, 2009 1:10:33 AM(UTC)
Remove the front bottom kick panel and verify the motor is not turning in spin. If so, you might have a bad door switch. I assume the drain pump works in spin and the motor turns during wash period.
