Our Whirlpool dryer has started not drying as well as it used to. It will now take about 2-3x longer to dry. The lint filter is clean, the exhaust hose is clean, this happens whether on Automatic or Timed dry (or low or high heat) & the timer DOES advance.
Can anybody please help tell me where to start looking/checking? Let me know it u need the serial # to the dryer! Thanks in advance.
* also, it does have a small squeak sometimes while the drum is turning, not sure if this is related...? *
Have you tried cleaning out the lint chute? At the bottom of mine I pulled out two handfuls of lint. You can get to it by the two screws by the lint screen and 4 screws behind the panel.
65GT350
Originally Posted by: 65gt350 Have you tried cleaning out the lint chute? At the bottom of mine I pulled out two handfuls of lint. You can get to it by the two screws by the lint screen and 4 screws behind the panel.
65GT350 No, haven't tried that...I have used a long brush down the lint chute though & gotten out a few fuzzies, but nothing major...I'll try this - Thanks!
Disconnect the unit's exhaust from the vent system. Take a pair of pantyhose. Put one leg into the other and attach this to the exhaust. Leave enough room behind the dryer so it can blow out like a windsock. Run a load. If it now dries OK, you have a vent problem If still no good, you have a machine problem. Either poor air flow or low/no heat Both can be checked when disconnected from the vent.
If you do not mind some lint blowing out you can do the same thing but without the pantyhose. |
THIS FORUM IS DEAD!!!!!!! |
I'll try it & let ya know what happens! Thanks!
