ckerdflag
#1 Posted : Sunday, January 4, 2009 10:24:03 AM(UTC)
ckerdflag
I have a Maytag washer, Model MAH4000AWW, Serial # 11280382WD. This washer came with the house we just bought, so I don't know how exactly old it is or its history. All I do know is that when you start a load and select WARM, you get hot water. To actually get warm water, you have to first select WARM, then select COLD, then select WARM again. With this sequence, you actually get warm water. If you start out on COLD then select WARM, you get hot. This is true for both the WARM/COLD wash/rinse selection as well as the WARM/WARM selection. Is this a sticking valve? How is the plumbing arranged on these things, one valve w/ two inlets or two separate valves for hot and cold? Are these hard to change yourself?
magician59
#2 Posted : Monday, January 5, 2009 6:15:40 AM(UTC)
magician59
These are dual valves, each side (hot and cold) controlled by individual solenoids. When the temperature is selected, the incoming water is monitored and controlled by a thermistor, which in turn is controlled and monitored by an electronic control board. There are ways to diagnose the operation of the components. The tech sheet that accompanies the machine is located within the console and is accessed by removing the back panel (six screws), unless a previous tech took it out. The tech sheet tells you step by step how to diagnose the problem. Take it out and carefully read through it before you use it. The inlet valve is as simple to replace as the fuel injector on your family auto.
#3 Posted : Monday, January 5, 2009 6:57:14 AM(UTC)
Sometimescan
#4 Posted : Sunday, February 22, 2015 11:32:49 AM(UTC)
Sometimescan
What did you find to be a resolution to the problem ?
I have the same Maytag washer, Model MAH4000AWW referenced in post from 2009. The water valve and control board were replaced by Maytag in 2002 following an early failure. Recently I have noted the problem with warm water flow referenced in that post, ie: If I select a warm wash it begins with both hot and cold valves running ( for about 3 seconds ) and then switches to HOT only. The only way to get warm is to then press either the cold wash or warm/cold wash and rinse cycle buttons, then back to the warm/warm, and it will fill correctly with warm water. This is also the only setting that would allow a warm rinse, but all rinse water fills are COLD.
And there is never any hot added to bring the cold water temperature up from the 55 degree well water that we have, so it is very old.
I am not sure if the thermistor is working or not. I do get warm water after resetting the cycle, but I am not certain if the warm fill is supposed to be calibrated at some higher temperature or if it is just the mix between flow rates on the hot and cold valves. That seems to be the only temperature adjustment that I have here.
