2 Pages<12
#11 Posted : Sunday, January 4, 2009 12:29:23 PM(UTC)
Check if there is 120VAC to the turntable motor while the control calls for heat. If there is no proper voltage and there is nothing wrong with the wires, then the control board is bad. The part number for the control board is in the above post.
Gonzo55
#12 Posted : Monday, August 15, 2011 4:04:28 PM(UTC)
Gonzo55
Gene:
Is there a new microwave replacement that will fit within the same footprint as the GE 191d2356g002? I would not mine upgrading if I can use the same oven.
Let me know.
Thanks,
Rich
#13 Posted : Monday, August 15, 2011 5:53:50 PM(UTC)
Hi Rich,
Check out what I found.
microwave won't heat (Microwave Repair)
by Suefink 2/13/2013 2:53:07 PM(UTC)
Microwave won't heat (Microwave Repair)
by gkronenberger 11/24/2012 5:02:07 AM(UTC)
brand new microwave won't heat sensor error (Microwave Repair)
by redcellocase 6/8/2012 7:47:31 PM(UTC)
by lilbart 1/17/2012 9:24:27 AM(UTC)
by frankish 12/8/2011 12:38:07 PM(UTC)
Whirlpool Microwave won't heat (Microwave Repair)
by Wendy Porter 12/2/2011 5:45:04 PM(UTC)
by vangoy 12/1/2011 5:03:01 PM(UTC)
by jlune423 6/28/2011 9:22:36 PM(UTC)
GE Profile Microwave won't heat? (Microwave Repair)
by bill007 3/3/2011 4:47:45 PM(UTC)
by mtorrey 2/12/2011 11:41:56 AM(UTC)
Microwave Won't heat food and turntable doesn't rotate (Microwave Repair)
by PaulieMo 1/24/2011 10:38:46 AM(UTC)
Microwave won't heat/Loud buzzing (Microwave Repair)
by grami 8/11/2010 5:14:13 AM(UTC)
Kitchen Aid Microwave Won't Heat Food (Microwave Repair)
by lmcalpin 7/20/2010 9:16:35 AM(UTC)
Microwave Won't Heat (Microwave Repair)
by cfairban 1/18/2010 10:21:36 AM(UTC)
Microwave won't heat, over the range Mcrw. (Microwave Repair)
by mbradyla 1/15/2010 10:52:20 AM(UTC)
2 Pages<12
