AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Motor humming and water comes but blades don't spin (water pressure problem?)
Motor makes noise not previously heard and no water pressure. Do I need the circulation repair kit or the motor? Where do I get schematic? Thanks.
If you don't/can't hear the circ motor at all it may be dead/burned out depending on how long the problem has existed. Linuxaz's me too post links to a parts page showing a schematic of sorts but nothing to do the repair by certainly. I have looked for a Bosch/Kenmore Elite service manual online and can't find anything. There is a post by justkoz - http://forum.appliancepartspros.com/52948-post2.html with an pdf attachment on reaching the heater which attaches to the sump/circ and is what I'll be following if I don't find anything else to drive by... Red
Solved the problem by replacing pump which comes as repair kit and is attached to the motor. Quite a process to disassemble machine and base. Impeller screws onto motor as previous thread indicates. Motor twists off of mount. Impeller is weak link because of constant hot water pumping, I believe.
Thanks that's what I was afraid of... guess I'll wait til the part comes in to begin so I'll [hopefully] remember where everything goes when putting it back together. Don't think I can get away with a missing screw or two unlike when I rebuilt my engine many years ago and had parts to spare at the end. :eek: Still ran for another 185k after that so they weren't too important...
Dishwasher Repair
