My boyfriend's oven element in the bottom was not working at all....he removed it to replace it and while he was away his grand-daughter turned on the oven and now nothing works in the oven or the top elements...what can we do now....I want to cook a turkey dinner in two days!! Help us please....
Did he check the circuit breakers for the oven?
What is the complete model number of the oven?
thanks Gene, actually he did and you were right on the money....thank you so much you saved Christmas....lol....
Hi Gene...well Christmas is over with but while away another problem was detected with this crazy oven my fellow has....it is working as far as the elements in the oven however it runs extremely high and just doesn't shut down....I even turned it on 150 and those burners got red hot....the make is Kenmore and I believe it is called Evolution....I don't have any other numbers for it....what next Gene??? I just worry about the grand-daughter turning it on and forgetting it.....dangerous to say the least. Thanks so much....Ann
Hi Ann, It's hard to say what is wrong without the model number. This link will help you to find it. Gene.
Ok Gene, thanks I will get it and then go from there....makes it hard when he and I live miles from each other....however I will get it....thanks again Gene....Ann
