tillelectric
#1 Posted : Tuesday, September 20, 2011 12:21:47 AM(UTC)
tillelectric
The refrigerator will not stop running.I turned the unit off for a couple of hours and then restart it ,still runs nonstop.
#2 Posted : Tuesday, September 20, 2011 4:07:26 AM(UTC)
Here are your parts, includes a wiring diagram.
Replacement parts for FRT18TJH models | AppliancePartsPros.com
First check the temperatures in the unit.
The freezer should be 0 to 5 degrees F.
There are 2 overall causes for it to run all the time.
1. The unit is not reaching the set point temperature so keeps running trying to get there. This can be a sealed system, an evaporator fan, a defrost or a door seal problem.
2. The unit is at or below set point but does not shut off. This is probably a thermostat problem.
