qt3110
#1 Posted : Monday, September 19, 2011 9:05:10 PM(UTC)
qt3110
My dryer has two problems.
1. The dryer runs but won't heat.
2. The timer does not work. It keeps running until I open the dryer door or unplug.
Can some one please me what could be the problem or how to troubleshooting it?
#2 Posted : Tuesday, September 20, 2011 4:26:25 AM(UTC)
Replacement parts for FRIGIDAIRE AEQ6000ES2 Frigidaire/dryer | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/p...r/134682200ts_wd_EFS.pdf
Try running the diagnostics.
You said the timer will not stop unless you unplug the unit so I am assuming that you removed power from the unit for about 5 minutes and the control board/timer did not reset (repair the problem).
Also here is a service manul which should be close to your unit
http://appliancedigest.c...ity-dryer-service-manual
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
More info on exactly what the timer is doing would be helpful.
qt3110
#3 Posted : Wednesday, September 21, 2011 4:01:45 PM(UTC)
qt3110
Thanks for your reply denman!
Yes, I removed power from the unit for 30 minutes but it did not solve the problem.
I ran some diagnostic per manual instruction. The console displays error code 'E9E' which I couldn't find it in the manual.
I couldn't tell if the timer is working. I set it to 30 minutes and after 30 minutes it no longer displays time. I need to verify that again.
