I have a 1948-49 Empire Gas Stove that needs a regulator for the oven.I have called the company that made them in Belleville,IL and they more less told me I'm out of luck,now, there has to be something somewhere.I need help,any suggestions?The metal plate on the inside under a burner says model# 38-1 serial# 38-1991,oven input per hour 20,000 BTU and built to AGA requirements for all gases.
You have been a member since:: 8/13/2008(UTC) Posts: 3,097
Can you see any part numbers on the regulator?
Nat
