dbbdb
#1 Posted : Thursday, January 1, 2009 5:13:33 PM(UTC)
dbbdb
After a power outage, our Frigidaire refrigerator keeps freezing food. I set the temps to 6 degrees (freezer), 47 degrees (refrigerator) but the unit keeps running and temps go to 6 degrees (freezer), 16 degrees (refrigerator). I placed the unit into manual defrost mode and cleaned coils, but nothing has helped. Any solutions?
knoxtoy87
#2 Posted : Thursday, January 1, 2009 10:15:05 PM(UTC)
knoxtoy87
check your defrost timer.
#3 Posted : Friday, January 2, 2009 1:17:36 AM(UTC)
Check your model #, this model # shows an electronic defrost control, not a mechanical one.
dbbdb
#4 Posted : Friday, January 2, 2009 1:57:40 PM(UTC)
dbbdb
Where is the electronic defrost control located? The model # is correct.
#5 Posted : Saturday, January 3, 2009 12:46:43 AM(UTC)
I would check the damper door if it has one. If ok, replace the control AP4362602
