I am having a problem with my dryer screeching and making grinding sounds...the last time it did this someone fixed it for me..it was the small pulley under the drum ...just needed lubricated as it was froze up. I want to fix it myself but what is the best way to get to it??? My manual doesn't show the best way to take it apart. Thanks to anyone that can help me out!
Here's a parts breakdown Model NDE5800AYW Use a putty knife to release the clips between the top & front panels-raise it like a car hood, then remove the screws along the top and the two screws on the bottom front, then lift up a little on the front panel and the belt making sure to note how the belt goes on. Lift up on the drum slightly and pull it out of the way, you can then access the rollers, shich probably need replacing. While you have it appart vacuum out the insides to help prevent a fire hazzard. Nat
THIS FORUM IS DEAD!!!!!!! |
