I am now told that I will need to replace the keypad control electronics Door latch assembly and the EOC Because it got too hot and these things are now bad. Does that sound right? Also, What is an EOC and what is the part number for that??
I have read some reviews on this oven and learned that this is a common recurring problem. This is going to have a total cost of about 400.00 to repair all that is bad. Is it really worth the expense if this is something that is likely to happen again?? What are the most recommended products with the least amount of problems???
