I've run into a problem installing a new ADC kit in my refridgerator. I had to replace the wiring harness in my unit with the one that came with the new ADC (P/N AP4909015). Everything was going fine until note 4 in the directions says that the wiring harness in the kit has a connector for the fast ice/fast freeze heater installed on the freezer control bulb. Well, my new harness does not have this connector. So what should I do? Proceed on and just lose this funtion, cut if off of my old harness and splice it into the new one, or I'm I just missing something else altogether?
Thanks for any help.
Here is the tech sheet for this unit. http://manuals.frigidaire.com/prodinfo_pdf/Anderson/240389615.pdfLooks like there is a problem with this kit or at least the instructions they provide from Frigidaire depending on the unit it is installed in. I think I would just loose this function rather than perhaps mis-wire something and cause other problems. Here is a link to an older post, though in his case the heater was there but the function was not on the ice/water keypad. http://forum.appliancepartspros...ht=frigidaire+thermostatSorry but without actually being there I cannot be of much help. The above poster's instructions seems to have said to do this. Please see the last post on Page 2. |
THIS FORUM IS DEAD!!!!!!! |
i was alll the way home.... Why is there no connector to the fast defrost?
I have GLRS267zaw4 ordered the new ADC IV, but the harness doesnt match up. as previously stated.
