sunnyyang
#1 Posted : Wednesday, September 14, 2011 9:35:58 AM(UTC)
sunnyyang
I have a Frigidaire refrigerator. The ice/water dispenser is not lighting up and is not dispensing water and ice but the ice maker is working. Using a non-contact voltage tester it appears there is power getting to the power board as well as to the control board behind the dispenser. What do I need to replace?
steventoo
#2 Posted : Saturday, January 21, 2012 2:54:46 PM(UTC)
steventoo
Check door safety switch ( light switch ), loose/off wire, ribbon cable for front buttons off/loose, bad board. Well, I did find out that the light bulb was broke off up inside of the dispenser, I replaced it and there is still no power to the door or the light. So it looks like when the light bulb blew out (before I owned it) a small fuse in behind the dispenser panel had blown. After removing all the tiny screwe and the removal of entire front panel I found this little dead fuse. I had to take a butter knife to pry the box open where the ribbon cable plugs in. In there you will see a tiny fuse. Test it! After replacing that fuse everything is working fine. I presume this fuse is a safety feature to prevent electrical shocks because that dispenser panel carries 120v into it. Next to all of that 120volts is flowing water and a light bulb. I hope this helps you.
