2 Pages<12
Minnesnowta
#11 Posted : Wednesday, September 14, 2011 8:55:12 AM(UTC)
Minnesnowta
I believe you are on the right track. The insufficient pressure in the house water line can be the culprit. Especially if the water goes through some filters.
Gene, finally getting around to my water issue again. Put in the filter plug and water still slow. Replaced water line and tub. Put in filter, still slow, Replace filter with plug. Now I have good water flow again. So I am confused. When I put the plug in my old water line tub it was still slow but with the new one it is fast. However, it is still slow with the filter attached to the new waterline/tub. So i am wondering if i got a bad filter also. Pressure from the wall is strong.
sellycrash
#12 Posted : Thursday, February 27, 2014 12:19:41 AM(UTC)
sellycrash
Finally I was able to find a clue to the problems I faced in this thread.
Thank you for the guidance of friends here
UserPostedImage
mguzman72
#13 Posted : Wednesday, April 23, 2014 12:06:13 PM(UTC)
mguzman72
UserPostedImage
what turned to be the issue with your refrigerator? I have an issue after changing the water filter where the water discharge became slow at the water dispenser...
http://diy.stackexchange.com/qu...r-from-dispenser-is-slow
GE Refrigerator Water Dispensing Slow Model# GSH22JSXLSS (Refrigerator & Freezer Repair)
by srivju 10/21/2010 7:23:30 AM(UTC)
2 Pages<12
