OK, Thanks very much abadfish66! I'll give it a try!
jayvee
Originally Posted by: abadfish66 I gave you the wrong part# for the board, You need a WR49x10152. Yes GE is having a repair program on some model boards, but your refer is not one under the rework. Your refer is a dual evaperator model and is not a model with the known problems even though it seems like it is the same. Very important!!! Do not use the part# WR55x10552, if you do your compressor will not run. Please order a WR49x10152, and follow the instructions that are included in the box, very important!!! One more question for you, do you her=ar the fresh food fan running? I'm Having the same problems with my fridge. Turbo cool never shuts down, Top of freezer and fridge warm and defrosting bottom cold. I was going to replace the main board but would like to know if my model # is on that falls under the rework program. Model # ESS25LSRDSS. Can anyone help. First Time using this site and Forums.
