2 Pages<12
bsaucer
#11 Posted : Sunday, September 11, 2011 11:27:47 AM(UTC)
bsaucer
Originally Posted by: ajs8 Go to Quoted Post
thanks for the reply bsaucer
The tub will fill to the correct level and will agitate. I will also empty just fine. I have reviewed other posts and am wondering if a clutch mechanism of some kind has worn down...it does work when I start it off spinning by giving it 'a hand' to start it off rotating.
My reply was for the original poster whose washer wouldn' fill. In your case, it does sound like the drive clutch is bad.
ajs8
#12 Posted : Sunday, September 11, 2011 12:02:49 PM(UTC)
ajs8
thanks bsaucer; your response confirms my thoughts. Now the next thing is what part number am I looking for; or is there a way to fix by using washers to increase the throw of the clutch. It is a canadian model and I have had problems locating the part. I enclose a picture.
thanks
ajs8 attached the following image(s):
bsaucer
#13 Posted : Sunday, September 11, 2011 1:33:11 PM(UTC)
bsaucer
I think it's called a "basket drive and brake assembly". It includes the pulley, yoke, brake, and spin tube. It requires a complete overhaul: Lift top. Remove agitator, tub ring, spanner nut, basket, drive block... Then lay down machine and remove braces, belt, pump, gearcase, etc... It's also expensive.
thanks
ajs8
#14 Posted : Sunday, September 11, 2011 2:44:06 PM(UTC)
ajs8
thanks bsauser,
I'll see if I can find a part number.
2 Pages<12
