How to download the Repair Manual for Kenmore - front loaded washer, year 2002. The bearings at the rear tub need to be replaced, I want to do it myself, step by step. Thanks in advance!
you have an incorrect model #. your model # should be around the door opening as it is open. more than likely the model # will start with 110. or 417. please re check it and post the correct model # here.
I found a sticker on the door frame, with model No. 970-C41062-00, made in USA 08/02, some people told me it might be 417.42042100 or 417.41042000. Is it possible to find the Repair Manuals for these models? Thanks!
