We seem to be having an intermitent problem with the spin cycle. Seems primarly to be when using the "ultra clean" settting. Not sure if the issue is the same with "permanent press" setting. Intermitent issues, and me not being the primary user does not allow me to always know.
Thanks in advance for your help. Kevin
Happened in Permanet Press as well, and fabric softner did not disperse from center.
Hi Kevin, The first thing I would check is the lid switch (#11 on the break down diagram). - The part number for the lid switch is AP3100001Gene.
