roryhowatt
#1 Posted : Sunday, December 28, 2008 5:31:03 AM(UTC)
roryhowatt
dishes are not clean. Is there filters that need to be cleaned or what else can I do?
footloose1
#2 Posted : Monday, December 29, 2008 8:32:51 PM(UTC)
footloose1
1) Check water level: The water level should be high enough in the base to touch the float. If too little water, there isn't enough to circulate with the proper amount of force.
2) Is there a "tower" that pops up from the base of the lower spray arm? While dishwasher is running, open the door and align the spray arms so they are positioned in the same direction (ie: toward you, or toward the side walls). Close door, allow to run 15 seconds and quickly open the door. Have the arms moved? Is the tower tipped slightly sideways? Check the base of the lower arm assembly. Depending on the model/brand, there might be one or two tabs that hold the arm/tower in place. If one or both tabs are broken, the assembly will tip slightly - just enough to redirect the force of water. The result - poor cleaning, esp the top rack. Solution: Replace lower arm assembly.
Hope this helps. Carole (footloose1)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
