ChrisR001
#1 Posted : Friday, November 2, 2007 3:35:50 PM(UTC)
ChrisR001
This just now started:
Dryer finished its cycle and quit spinning. I went back to pull the clothes out and hear a hissing or buzzing sound. My husband commented that there was electrical interference on the TV. Control knob was in Off position. I turned the knob a little and it quit making noise, then it started hissing again in the OFF position and the interference showed up on the TV again. So we turned the circuit breakers off to the dryer.
We were kind of needing a direction as to what is wrong with our dryer. It spins, it heats, just hisses like a snake when it's suppose to be off! Controls worn out? maybe a short?
Thanks for any advice!!!!
Chris
fixxit
#2 Posted : Friday, November 2, 2007 3:40:48 PM(UTC)
fixxit
hi ChrisR001 your model # is important for proper diag. and parts. please post complete model # here
ChrisR001
#3 Posted : Friday, November 2, 2007 3:47:40 PM(UTC)
ChrisR001
I just knew you'd ask me that.....and I finally found it:
LSR8233EQ0!
fixxit
#4 Posted : Friday, November 2, 2007 3:52:15 PM(UTC)
fixxit
er....keep looking. that model # comes up as a washer.
ChrisR001
#5 Posted : Friday, November 2, 2007 4:00:22 PM(UTC)
ChrisR001
OK, one more time and this was on the dryer:
LER5636EQ2
fixxit
#6 Posted : Friday, November 2, 2007 7:23:48 PM(UTC)
fixxit
thats better. comes up as a dryer this time. must likely culprits are timer part # AP2976148 or a ground in side the case. disconnect the ducting and the 240 plug. unscrew all the screws in the back pannel and look for burn or wires that are off. you probably wont find them but it never hurts to check. i suspect your problem is the timer. good luck and post your results here.
ChrisR001
#7 Posted : Saturday, November 3, 2007 3:18:13 PM(UTC)
ChrisR001
Thanks for the info.
Will let you know what we find!
Chris
Guest (4)
