othater
#1 Posted : Friday, December 26, 2008 4:17:00 PM(UTC)
othater
Hello,
The bottom part of the control panel is loose like the tabs or screws holding it down are broken or fell off.:confused:
What part might I be looking at? and the cost.
Is that replaceable by myself?
Thank you for any replies up front.:)
Just viewed the diagram.
would it be the panel control or bracket control?
TechnicianBrian
#2 Posted : Friday, December 26, 2008 6:05:34 PM(UTC)
TechnicianBrian
The control panel tabs have probably broken off allowing the bottom of the panel to feel loose. A new control panel Part#AP4359002 should do the trick and yes you can do it yourself.
othater
#3 Posted : Friday, December 26, 2008 8:29:34 PM(UTC)
othater
Thanks for the quick reply Brian,
Is there a schematic that shows me how to take apart and replace?
I've seen some other threads with attachments of manuals from other members.
TechnicianBrian
#4 Posted : Saturday, December 27, 2008 7:53:46 AM(UTC)
TechnicianBrian
There is no repair manual, but after you turn off the power, the upper grill is held in place with a couple screws that come down from the top. Once removed, the grill pulls forward and off. There is one screw that holds the control panel in place and once it is removed, the control will slide up and off. Then just make note of which wire harness goes where and move the control board to the new control panel. Once you see it, it is pretty easy to do.
othater
#5 Posted : Saturday, December 27, 2008 10:04:12 AM(UTC)
othater
Are there components on the new control panel or am I transferring all the old components (control board) to the new panel.
Just asking, before I spend $95.00 I'm hoping for new components and not just for a piece of plastic with new tabs.
