well i took the belt off and motor still acts the same. in agitate mode it just hums. if i spin the pully, then the motor takes off. of course with belt on i cant do that. so far i ve replaced the capacitor twice, the motor and i still have the problem. (sent the new motor back). i just dont understand how the motor can kick in fine on spin, but dont have the stuff to start in the agitate mode. whats stopping it? the trany seems stiff to spin by hand.either way... but what do i know? the motor has no problem moving it on spin. Anybody got any ideas? thanks KRF
well i took the belt off and motor still acts the same. in agitate mode it just hums. if i spin the pully, then the motor takes off. of course with belt on i cant do that. so far i ve replaced the capacitor twice, the motor and i still have the same problem. (sent the new motor back). i just dont understand how the motor can kick in fine on spin, but dont have the stuff to start in the agitate mode. whats stopping it? the trany seems stiff to spin by hand.either way... but what do i know? the motor has no problem moving it on spin. Anybody got any ideas? thanks KRF
i took the belt off and got same results. motor just humms in agitate mode. i can spin the pully and the motor takes off in agitate mode. just wont on its on. of course with belt on i cant do this. ive tried 2 capacitors and a new motor. i can turn the trany with belt off any direction with no problem. its stiff to turn, but what do i know. the mortor has now problem starting in spin cycle. looked behind the contol panel and and no signs of anything shorted out. whats left but timer? any suggestions? KRF
