Gallo
#1 Posted : Thursday, November 1, 2007 1:48:32 PM(UTC)
Gallo
Still need help with my error code on oven. It shows PF and the time but does not respond to touch pad. I tried to reset but same result. Do I need The control panal or the electronic control unit the control panel hooks up to. Thanks
#2 Posted : Friday, November 2, 2007 12:41:37 PM(UTC)
Hi Gallo
Most likely the problem with your oven is a bad control panel. If your oven is less then a year old it should be under the manufacturer warranty , free of charge to you. If it's not under the warranty, I need you to post the complete model number of the oven to help you with the right part.
Gallo
#3 Posted : Friday, November 2, 2007 2:04:49 PM(UTC)
Gallo
Thanks for the advice. The unit doesnot have warranty and the complete model # is gw395leps00
Thanks Gene
#4 Posted : Friday, November 9, 2007 11:17:56 AM(UTC)
Hi Gallo
You did not provide the color of the unit and I'm going to post the part numbers for all available colors.
- The part number for the white control panel AP4261256
- The part number for the biscuit control panel AP4261905
- The part number for the black control panel AP4263577
- The part number for the stainless steel control panel AP4263578
Good luck.
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Whirlpool Oven - Controls Don't Work (Oven Repair (including Ranges and Cooktops))
by Guest 3/25/2024 10:18:22 AM(UTC)
Multiple failures in Whirlpool oven? (Oven Repair (including Ranges and Cooktops))
by Guest 3/22/2024 6:55:50 AM(UTC)
Whirlpool Oven WFE770H0FZ2 (Oven Repair (including Ranges and Cooktops))
by Guest 2/9/2024 7:03:09 AM(UTC)
Whirlpool Oven GBD307PDS7 Shuts down and Upper Blower fan does NOT work (Oven Repair (including Ranges and Cooktops))
by rswilson1844 12/3/2023 11:18:33 AM(UTC)
Whirlpool Oven Cooling Fan (Oven Repair (including Ranges and Cooktops))
by Tfastle 11/21/2023 9:59:51 AM(UTC)
Whirlpool oven - only one heating element? (Oven Repair (including Ranges and Cooktops))
by smithhead 11/3/2023 2:42:01 PM(UTC)
Whirlpool Oven Temperature Low (Oven Repair (including Ranges and Cooktops))
by topthumb 1/23/2023 11:37:05 AM(UTC)
Whirlpool oven WFE505W0HB2 (Oven Repair (including Ranges and Cooktops))
by Guest 1/7/2023 5:44:02 AM(UTC)
Whirlpool oven broil element doesn't go off and code F3 E2 (Oven Repair (including Ranges and Cooktops))
by Right_to_Repair 3/29/2022 1:54:22 PM(UTC)
Whirlpool oven approximately (2006) (Oven Repair (including Ranges and Cooktops))
by Guest 2/28/2022 3:02:09 PM(UTC)
Whirlpool oven shuts off overnight (Oven Repair (including Ranges and Cooktops))
by Guest 4/15/2021 3:53:14 PM(UTC)
Kitchen Aid/whirlpool oven does not light on the first try (Oven Repair (including Ranges and Cooktops))
by Deintinis 11/22/2020 7:42:29 AM(UTC)
Whirlpool oven won’t stay lit (Oven Repair (including Ranges and Cooktops))
by jc0786 11/15/2020 7:11:47 AM(UTC)
Whirlpool Oven - RBS307PVS03 - Fuse for front control (Oven Repair (including Ranges and Cooktops))
by lmagdaleno 11/8/2020 11:50:57 AM(UTC)
