dsweep
#1 Posted : Wednesday, December 24, 2008 5:51:55 PM(UTC)
dsweep
Hi. I have a 2yr old Dacor cooktop that continuously sparks even when the gas controls and gas supply if off. I have tried cleaning the electrodes but the problem persists. Can anyone help me?
#2 Posted : Friday, December 26, 2008 12:32:45 PM(UTC)
Check all the ignition switches and if there is nothing wrong then replace the spark module.
- The part number for the ignition switch is AP3392485
- The part number for the spark module is AP3160674
dsweep
#3 Posted : Saturday, December 27, 2008 5:05:54 AM(UTC)
dsweep
Gene: Thanks for the advice. I'll work on the repair.
#4 Posted : Saturday, December 27, 2008 12:23:35 PM(UTC)
Keep us posted.
dsweep
#5 Posted : Tuesday, December 30, 2008 6:01:27 PM(UTC)
dsweep
Keep us posted.
Thanks Gene. Your advice was excellent.
#6 Posted : Friday, January 2, 2009 6:47:31 PM(UTC)
You are welcome. Happy New Year!
Udo
#7 Posted : Saturday, September 15, 2012 7:14:27 AM(UTC)
Udo
We just had a very similar issue with our 5-burner Bosch stovetop after a water spill: All igniters were continuously firing. Turning on one specific burner would stop the firing, but others would not do that.
Luckily after a few (10 or 15) minutes of helplessly fiddling around with the unit the problem began to clear up on its own very quickly. No repair was needed. I hope this proves helpful to someone else. :)
