Jim Brizz
#1 Posted : Tuesday, December 23, 2008 8:08:10 AM(UTC)
Jim Brizz
When I start the wash cycle, the water is just dribbling out of the bottom on the inside of the washer. The motor is obviously running, but there's just no pressure. Do I have a faulty pump?
libertyappl
#2 Posted : Tuesday, December 23, 2008 8:21:40 AM(UTC)
libertyappl
Most likely the water valve is your problem.
Here's a parts breakdown Model GSD3125F00BB
Nat
Jim Brizz
#3 Posted : Thursday, December 25, 2008 8:55:40 AM(UTC)
Jim Brizz
Thanks for the response. I did just replace the water valve.
#4 Posted : Friday, December 26, 2008 1:50:51 AM(UTC)
I would pull off the inner door panel and look at the wires going to the selector switch, they have had a lot of problems with the switch failing from soap contamination. New Part AP2617405 includes a shield to prevent this.
If ok, feel the water valve while it is filling, should fill for at least 40 seconds, if ok, you have weak water pressure to the valve.
Jim Brizz
#5 Posted : Friday, December 26, 2008 7:45:07 AM(UTC)
Jim Brizz
richappy- Thank you for the tip. I pulled the inner panel and the wiring and switch looked good. One thing I noticed- I "cheated" the latch switch so I could run the washer with the door open. Water is coming up through the center assembly, but at the same time water is draining down in the "sump" (don't know proper term). Is that draining function controlled by the timer assembly? Thank you for any replies.
#6 Posted : Saturday, December 27, 2008 12:58:45 AM(UTC)
You have a jammed closed drain solenoid in back of the front kick panel.
Jim Brizz
#7 Posted : Tuesday, December 30, 2008 5:13:53 PM(UTC)
Jim Brizz
Richappy- After trying all of the suggestions, I now have plenty of water in the washer. Thanks to everyone for their help. Now I can move on to the next problem! Thanks again.
Guest (5)
No water pressure (Dishwasher Repair)
by walter3ca 7/28/2013 4:16:13 PM(UTC)
No water pressure (arms not turning) (Dishwasher Repair)
by aher 6/21/2012 8:19:54 AM(UTC)
frigidair dishwasher has no water pressure (Dishwasher Repair)
by taylormade1971 10/23/2009 5:43:01 PM(UTC)
