wildbill253
#1 Posted : Sunday, September 4, 2011 11:56:17 AM(UTC)
wildbill253
Please Help,im Going Nuts, On This Cooktop, Ge Model # Jgp328wec2ww, The Ignighters Were Sparking With All The Knobs Turned Off, I Read Most Of The Exsisting Blogs Or Suggestions, I Replaced All 4 Ignighters, The Wiring Harness, The Spark Module, Now The Upper Right B Orner Is Randomly Sparking No Matter What Knob You Turn, Is The Wiring Harness That Looks Different Placed A Certian Way, There Is No Ground Wire On The Spark Module, ? Any Suggestions ? Thanks Bill
wildbill253
#2 Posted : Thursday, September 8, 2011 11:42:19 AM(UTC)
wildbill253
ok, after checking for correct positioning of the new wiring harness, (tested continuity related to swich position), i now have 3 out of 4 ignighters working, there are no more possible parts, if i hold a screwdriver near the ignighter and burner the spark jumps to the burner, ? but the swich will not acivate the ignighter, is this a grounding problem, the harness tests ok with continuity when controller knob is turned, the wire from the control knob to the burner tests ok for continuity, any suggestions would be greatly welcomed. thanks bill
