rich2k
#1 Posted : Saturday, September 3, 2011 3:59:52 PM(UTC)
rich2k
Refrigerator and freezer not cold, just a little cool, I noticed evaporator fan motor not working, if i replace should this fix the problem. I checked and got 13.4 volts from red and white wire and 13.4 from white and yellow wire ...
#2 Posted : Sunday, September 4, 2011 11:13:42 AM(UTC)
Check your schematic, some models change wiring to the evaporator motor.
You must have a square wave on one set of pins to the motor, chops the 13 volts in half to 6.2 as measured on a dc meter. This is a 6 pole induction motor, will not work without a square wave. If missing, the motherboard is bad. It is also best to replace the evaporator motor at the same time.
