bobdole
#1 Posted : Thursday, December 25, 2008 11:08:08 AM(UTC)
bobdole
Gas range, oven will work in broil but not in bake.
#2 Posted : Friday, December 26, 2008 10:22:19 AM(UTC)
Check for 120VAC to the Bake igniter (#316 on the break down diagram) while the control calls for Bake.
If there is proper power then replace the igniter.
If there is no proper power then replace the Electronic Range Control (#16 on the break down diagram).
- The part number for the oven igniter is AP2014008
- The part number for the ERC is AP2025164
