Kelcraw
#1 Posted : Wednesday, December 24, 2008 8:32:32 AM(UTC)
Kelcraw
Our dryer runs but we have no heat. Happened in the middle of a load.
misterfixall
#2 Posted : Wednesday, December 24, 2008 1:47:29 PM(UTC)
misterfixall
it may be thermal fuse or safety thermostat or ignitor or valve kit
kayakcrzy
#3 Posted : Sunday, December 28, 2008 2:35:07 PM(UTC)
kayakcrzy
Or Not!!!!!!!! No seriously, your model does not come up, but if you have the model where the back comes off the dryer, you might only need to replace the thermal fuse. It is white in color, and is about an inch and a half long, by a half inch wide. It has 2 wires coming to it. You can take the 2 wires off, and put the terminal ends together, and put some tape around it so it does not hit metal, and plug it in and see if it works, If so DO NOT run the dryer with the thermal fuse jumped out. It is a saftey. If it does not come on, it is either the ignitor, or the sensor. I would need to know if the ignitor comes on, after that to help you the rest of the way. Tom
LG Gas Dryer No Heat - Control Panel? (Dryer Repair)
by TomDBBills 1/29/2022 4:03:42 PM(UTC)
LG gas dryer no heat (Dryer Repair)
by Guest 8/15/2021 10:28:45 AM(UTC)
Belarus tombeird 11/8/2017 2:32:42 PM(UTC)
Whirlpool gas dryer no heat (Dryer Repair)
by alabamainnevada@yahoo.com 6/23/2015 5:54:15 PM(UTC)
Gas Dryer NO HEAT/FLAME and possible bad timer? (Dryer Repair)
by noles9399 2/26/2015 10:12:14 PM(UTC)
maytag gas dryer no heat (Dryer Repair)
by steve5024 11/8/2014 8:57:28 AM(UTC)
Hotpoint gas dryer no heat (Dryer Repair)
by Erich4130 8/28/2013 3:45:28 PM(UTC)
by huggard42 5/30/2013 4:34:58 PM(UTC)
Gas Dryer No Heat (Dryer Repair)
by AkZipper 11/29/2012 4:14:41 AM(UTC)
ge gas dryer no heat (Dryer Repair)
by mdelgiu1 11/7/2012 1:23:14 AM(UTC)
Ge gas dryer no heat (Dryer Repair)
by moby2000 10/25/2012 9:04:28 AM(UTC)
Kenmore Gas Dryer No heat (Dryer Repair)
by Resultsnow 9/8/2012 11:14:56 AM(UTC)
Gas dryer no heat (Dryer Repair)
by Brent gordon 7/31/2012 1:36:06 PM(UTC)
by petec357 6/21/2012 3:05:37 AM(UTC)
Frigidaire gas dryer no heat (Dryer Repair)
by mbarone 3/18/2012 4:25:38 PM(UTC)
