2 Pages12>
fred08
#1 Posted : Friday, September 2, 2011 3:10:27 AM(UTC)
fred08
I have a Magic Chef Model CGR3742CDQ gas stove. The upper burners work but the oven will not heat up. There is no gas smell when the oven is on. I am assuming for the moment that it is a faulty ignitor but am unsure as to what part number is required. Any help would be appreciated.
Joe / APP Team
#2 Posted : Friday, September 2, 2011 8:07:34 AM(UTC)
Joe / APP Team
Fred,
You're on he right track, most ignition and heat problems in a gas oven are due to a weak igniter,
Part number: AP4096256
You can test for 3.2 to 3.6 VAC, at the wires on the burner safety valve wires, or an amperage draw of 3.2 to 3.6 amps, with a clamp on ammeter, either way, the igniter has to be in the ignition process (on and glowing).
Good Luck,
fred08
#3 Posted : Monday, September 12, 2011 7:54:52 AM(UTC)
fred08
Thanks for your input. Ordered part, installed and all is well. Appreciate your help.
Joe / APP Team
#4 Posted : Monday, September 12, 2011 1:53:34 PM(UTC)
Joe / APP Team
Fred,
Great job, we're glad you're up and running. It was our pleasure to assist, and Thanks for the update.
:D :D :D
romerohome
#5 Posted : Monday, September 12, 2011 2:56:13 PM(UTC)
romerohome
Hi fred, Im having the same problem.. Was your old igniter still turning red ? I'm thinking mine is just weak ???
Joe / APP Team
#6 Posted : Tuesday, September 13, 2011 5:17:27 AM(UTC)
Joe / APP Team
Romero,
Yes, a glow bar igniter can glow red, and still be weak. A non technical test would be to observe the glow bar, It should glow "white" hot in 60 to 90 seconds from the time the glow starts, if not the igniter is weak, and needs to be replaced.
Good Luck,
GEdmonds
#7 Posted : Tuesday, September 13, 2011 3:37:14 PM(UTC)
GEdmonds
I have a GE gas range JGBS22BEH3WH that won't light the oven, either. Cooktop works fine. The glow bar doesn't do anything, doesn't even get warm. Does this seem to point to the glow bar, or the thermostat?
Joe / APP Team
#8 Posted : Wednesday, September 14, 2011 5:18:44 AM(UTC)
Joe / APP Team
G,
In your case, you'll need to remove the igniter and check for a physical break in the igniter assembl. If you have a multimeter it wouls be graet to check for a resistance reading.
If the igniter does not glow at all, it's still likely you have a bad igniter or a loose wire, but could also be a thermostat / control.
Good Luck,
GEdmonds
#9 Posted : Wednesday, September 14, 2011 3:19:14 PM(UTC)
GEdmonds
Joe, thanks for the input. I'll give that igniter test and see what happens since it appears to be intact!
Joe / APP Team
#10 Posted : Thursday, September 15, 2011 5:10:29 AM(UTC)
Joe / APP Team
G,
Great, let us know what you find.
Guest (6)
Oven does not heat up (Oven Repair (including Ranges and Cooktops))
by drpflyers 7/21/2015 1:32:17 PM(UTC)
oven does not heat up (Oven Repair (including Ranges and Cooktops))
by candyburch 2/4/2011 2:33:48 PM(UTC)
Oven Does Not Heat Up (Oven Repair (including Ranges and Cooktops))
by JIM1955 2/4/2011 6:23:20 AM(UTC)
Oven does not heat up, ignitor lights! (Oven Repair (including Ranges and Cooktops))
by billjohn 7/12/2010 1:28:09 PM(UTC)
2 Pages12>
