wlemon3
#1 Posted : Friday, September 2, 2011 4:06:32 AM(UTC)
wlemon3
House was struck by lightning and fridge will not cool, runs fine, lights all function. Tried changing board on water dispenser but no success. Can not change temp. settings. Is this a motherboard issue? Can the unit be saved?
#2 Posted : Friday, September 2, 2011 4:54:47 AM(UTC)
Pull the motherboard cover off, remove the 3 pin power connector, and put a wire jumper between the mating pins that are marked line and comp noted on the motherboard. Plug in fridg. if the compressor runs good and starts heating the condenser, then I would replace the motherboard, I think AP4436216, just check.
