richie33
#1 Posted : Tuesday, August 30, 2011 12:15:41 PM(UTC)
richie33
washer starts to fill then stops after about 15 seconds.
the timer is good, the water level switch is good , the hose is not pluged.
any sugestions
sidfink43
#2 Posted : Wednesday, August 31, 2011 5:40:37 PM(UTC)
sidfink43
When it stops check and see if 120v is getting to the water valve assembly. If it is, replace the assembly, if not probably need to replace timer.
Samsung Top Load Washer starts to fill then stops, code nF (Washer Repair)
by chris603 2/15/2017 7:52:28 AM(UTC)
Washer starts to fill then stops lights blinking (Washer Repair)
by Katmat 6/27/2012 9:57:04 AM(UTC)
washer starts to fill then stops (Dishwasher Repair)
by richie33 8/30/2011 11:42:32 AM(UTC)
