need4help
#1 Posted : Friday, November 2, 2007 6:30:19 AM(UTC)
need4help
I am looking for help to remove the front cover off the water/ice dispenser so I can get to other parts to clean. What is holding the piece on and what is the best way to remove it so the cover doesn't get broke? Thanks.
fixxit
#2 Posted : Friday, November 2, 2007 9:48:38 AM(UTC)
fixxit
this might be a learning experiance for you, GENTLY pull the lower portion of the face plate. it may seem as if it wont come off, but it will. the trick here is to pull firmly enough to pop it off but not so hard that it breaks. good luck and post your results here
