2 Pages<12
mnando88
#11 Posted : Tuesday, August 30, 2011 5:12:08 PM(UTC)
mnando88
Originally Posted by: Joe / APP Team Go to Quoted Post
Nando,
Your dryer is working correctly, as designed. In the "auto dry" cycle the timer circuit (tm to orng) allows neutral to the timer motor, when the burner cycles off on the regulating thermostat neutral is accomplished to the timer motor and the timer advances.
Your issue is most likely a clogged or restricted exhaust vent system, possibly a "weak" high limit thermostat, or an air leak at the drum or blower seal.
Good Luck,
Thanks. Is there anyway to check the thermostat to see if it is "weak"?
Joe / APP Team
#12 Posted : Wednesday, August 31, 2011 5:24:38 AM(UTC)
Joe / APP Team
Nando,
No, not really, if it's working, it may be opening the circuit too early.
The hi limit thermostat is designed and operates as a safety device, it's not designed to operate on a continuous basis, ( ideally, it should never operate).
It's just a process of elimination, or educated guess.
timer issue?? (Washer Repair)
by ldutton 10/16/2009 8:09:22 AM(UTC)
2 Pages<12
